adjust column order
berniebee
adjust column order
Sat Nov 08, 2014 10:40 am
Hello
Can not seem to figure how to adjust column order in MW 6.54.
This is the view I get but the up and down arrows to move columns are not there ?
Thanks for help
Re: adjust column order
Sat Nov 08, 2014 12:20 pm
If you go into your Control Panel >> Display >> look to adjust the DPI, uncheck the option to use Windows XP style DPI scaling >> logoff/logon >> hopefully you see the option then. Though this may make some programs real ugly, so I expect once you have the columns in the desired order you'll want to switch it back.
Sat Nov 08, 2014 12:21 pm
Or just reduce the DPI back to 100% temporarily.
berniebee
Sat Nov 08, 2014 2:44 pm
rusticdog wrote:If you go into your Control Panel >> Display >> look to adjust the DPI, uncheck the option to use Windows XP style DPI scaling >> logoff/logon >> hopefully you see the option then. Though this may make some programs real ugly, so I expect once you have the columns in the desired order you'll want to switch it back.
Just tried that still did not work.
