2.0 RC App for iOS
2.0 RC App for iOS
Wed Nov 19, 2014 2:49 pm
Installed here completed sign in and Mai Check. So far so good. Turned on Notifications and will observer and report. Continuing to test.
Re: 2.0 RC App
Wed Nov 19, 2014 3:46 pm
Are the "push notifications turned on at the server end?
Re: 2.0 RC App
Wed Nov 19, 2014 4:50 pm
Yes, notifications should be working all ok. You'll need to enable them for each email account in the email account settings though
Re: 2.0 RC App
Wed Nov 19, 2014 5:07 pm
nick.bolton wrote:Yes, notifications should be working all ok. You'll need to enable them for each email account in the email account settings though
Turned them on now on three of my four accounts.
Re: 2.0 RC App for iOS
Thu Nov 20, 2014 1:26 am
Notifications working A Ok.
A suggestion for your consideration - default the Notification tick boxes to On.
Thu Nov 20, 2014 4:02 am
Ok, yes. They should be on if entering manually, but syncing...We'll take a look
Thu Nov 20, 2014 6:46 am
nick.bolton wrote:Ok, yes. They should be on if entering manually, but syncing...We'll take a look
Probably a cockpit problem on my end. I did not need to sync after the install to my guess is that the prior account settings were unchanged e.g. no permissions set.
If you cannot change it on the server side then my suggestion would be to put in a "heads up" note in the forum for the existing users.
Fri Nov 21, 2014 1:57 am
Something to take a look at. Not a show stopper.
In the iPad Settings Notification for MWM there is an option to limit the number of notifications to (n). My observation regarding the view on the lock screen is that this is not being honored.
Fri Nov 21, 2014 6:52 am
Hmm, thanks. We'll take a look. Yes notifications can get a bit annoying
Fri Nov 21, 2014 11:32 am
Ok, I"ve been trying this. I limited it to 1 notification on the lock screen and it seems to be limiting it to 1 notification. then I increased it back to 5 and it's working there too.
Fri Nov 21, 2014 3:21 pm
nick.bolton wrote:Ok, I"ve been trying this. I limited it to 1 notification on the lock screen and it seems to be limiting it to 1 notification. then I increased it back to 5 and it's working there too.
The multiple notifications are on the Lock Screen, it appears that the Notification Area does conform. I was under the misconception that the (n) controlled both.
Tue Nov 25, 2014 3:00 pm
Is there a sound alert embedded in the app? I have the sound setting turned on in notifications.
Tue Nov 25, 2014 3:08 pm
No the only setting is for notifications, and the mobile platform handles the rest (type of notification)
Tue Nov 25, 2014 4:22 pm
nick.bolton wrote:No the only setting is for notifications, and the mobile platform handles the rest (type of notification)
Does MWM specify the type of notification e.g. New mail?
I see the other notifications but no sound
Tue Nov 25, 2014 4:31 pm
It's just new email. If you go in to your IOS Settings>>Notifications>>MailWasher, it should let you specify sounds, banners etc
