2.0.0 Synch of Friends and Blacklist
cfheinz
Guardian Gecko
Sat Nov 22, 2014 8:27 am
I installed MWM 2.0.0 on my iPad using the Testflight app. The email account synched correctly, but Friends and Blacklist aren't synching when I run synch from MWP 7.4.0. I've made several attempts. Am I missing something?
Carl Heinz
Re: 2.0.0 Synch of Friends and Blacklist
Sat Nov 22, 2014 10:24 am
So the lists are not going from MW Pro to MW Mobile? The sync is only one way.
cfheinz
Guardian Gecko
Sat Nov 22, 2014 12:12 pm
Yes, I'm synching from MWP.
Carl Heinz
Mon Nov 24, 2014 10:45 am
Do you have any entries in the friends or blacklists which might have odd characters like apostrophes or plus signs etc?
cfheinz
Guardian Gecko
Tue Nov 25, 2014 12:55 pm
No. Some have "-" or "_".
Carl Heinz
Tue Nov 25, 2014 2:12 pm
Ok, those should work fine. Can you try and sync again and then go to MailWasher>>Help>>User Files, then send me the log file for today? [email protected]
cfheinz
Guardian Gecko
Wed Nov 26, 2014 4:15 am
See attached.
MW Log.jpeg (448.64 KiB) Viewed 10629 times
Carl Heinz
Wed Nov 26, 2014 7:40 am
Not quite what I wanted :)
Can you try and sync again (MailWasher>>Settings>>Sync>>Mobile) and then go to MailWasher>>Help>>User Files, then send me the log file for today? [email protected]
cfheinz
Guardian Gecko
Wed Nov 26, 2014 6:15 pm
Nick,
I had tried syching mobile three times before doing the log capture. I see that Testflight has a new version. Should I install that version of MWM before trying again?
Carl Heinz
Wed Nov 26, 2014 6:31 pm
Yes, please install the new version, then try and sync your settings again then send me the logs from help>>Common Files>>Logs. Thanks!
