MWM2.0 incorrct Username or Password
Al Darby
Guardian Gecko
Thu Dec 11, 2014 11:50 am
H-E-l-P Can't use MWM on my iPad
Al
I come from a LAN downunder
3.6GHz Core i7 | 24GB RAM | 6TB HDD (1TB Samsung 850 EVO SSD)
Win 7 Ultimate x64 SP1 | VMWare for WinXP
(WinXP Mode Sux)
Re: MWM2.0 incorrct Username or Password
Thu Dec 11, 2014 11:58 am
Got anymore info? What email provider? Does it work in MailWasher Pro?
PeterJF
Thu Dec 11, 2014 2:11 pm
Version 2.0.0 updated today on my ipad and I also can no longer log in. The message is invalid username or password (username asked for is an email address).
I was using it earlier under the old version prior to the update.
I tried to reset password but nothing seems to have happened about that either
Thu Dec 11, 2014 2:26 pm
You need to create a new login for this version, we've had to discontinue the old one. So go to 'Create Account' and enter an email address and password to use as a 'Firetrust Login', then you'll be able to enter your email accounts. If also using MailWasher Pro, then go to Settings>>Sync, logout, then login and select v 2.0 and enter your Firetrust Login details
PeterJF
Thu Dec 11, 2014 2:44 pm
Good thanks now OK
