MailWasher Mobile 2.0 Released - FAQ's here
Thu Dec 11, 2014 2:43 pm
MailWasher Mobile 2.0.0 is available now in the following AppStores
Apple: iTunes Appstore at https://itunes.apple.com/nz/app/mailwas ... 02970?mt=8
Android: Google Play Store at https://play.google.com/store/apps/deta ... mailwasher
Windows Phone: WP8 Store: http://www.windowsphone.com/en-us/store ... e31661b5b6
1. Your old username/login no longer works. We replaced the system and now you need to create a new one. So go to 'Create Account' and enter an email address and password to use as a 'Firetrust Login', then you'll be able to enter your email accounts. If also using MailWasher Pro, then go to Settings>>Sync, logout, then login and select v 2.0 and enter your Firetrust Login details just created.
2. Syncing IMAP email accounts - the current released version of MailWasher Pro had IMAP sync disabled so it won't let you sync IMAP type email accounts. Please download and install this version to sync your IMAP email accounts.
http://cdn.firetrust.com/downloads/mail ... 112014.exe
3. Trouble getting in to Gmail? Gmail has probably blocked your account from being used with MailWasher Mobile, so visit https://myaccount.google.com/ then go to 'Recent Activity' to unblock the app. Also creating an application specific password should help https://support.google.com/mail/answer/1173270?hl=en
