RESOLVED MWM Icon MIA in iTunes Installed App area
Sat Dec 27, 2014 2:30 am
Just noticed that the MWM Icon is not showing properly in the iTunes Installed app section.
Here is what I see:
MWM ICON MISSING.jpg (3.61 KiB) Viewed 4402 times
Re: MWM Icon MIA in iTunes Installed App area
Sat Dec 27, 2014 2:46 am
Solution found.
The problem was likely caused by the old Beta version installed from my disk drive download. When I used the Get Info option it pointed there.
I then went to the iTunes App store, found the App and then did a download from there and the problem is now solved.
