Linux VPS - CentOS 6
Problems/tips/tricks with MailWasher Enterprise and Linux
DaveWilliamson
Sat Feb 28, 2015 3:22 am
Has anyone had any problems with installing on CentOS 6 as the company I am using seem to be having major problems with the install.
Do any other software need installing to work along side MWS?
The company I am keen to go with keep getting libs error messages and Nick has been great in pointing me in the right direction as much as he could.
How much memory does MWS take up ?
Last edited by DaveWilliamson on Sat Feb 28, 2015 4:29 am, edited 1 time in total.
DaveWilliamson
Re: Linux VPS - CentOS 6
I have found 1 host which can install it but it keep disconnecting, here is the log
Now the server has enough memory and do not find any other issues with it.
I have pasted the log of mwesd bellow. Kindly consult it with the script vendor and update us with details.
2015-02-27 15:10:54 [1863509792] Info: starting mwes version 2.8.1.4 {U64}
2015-02-27 15:10:54 [1863509792] Info: environment....
2015-02-27 15:10:54 [1863509792] Info: cfs_max_cache_size::20000
2015-02-27 15:10:54 [1863509792] Info: database_location::/opt/mwes
2015-02-27 15:10:54 [1863509792] Info: log_level::3
2015-02-27 15:10:54 [1863509792] Info: logging::/var/log/mwes/
2015-02-27 15:10:54 [1863509792] Info: rbl_max_cache_size::20000
2015-02-27 15:10:54 [1863509792] Info: root_document::/opt/mwes/mwes/
2015-02-27 15:10:54 [1863509792] Info: use_syslog::0
2015-02-27 15:10:54 [1863509792] Info: Initialising database....
2015-02-27 15:10:54 [1863509792] Info: Initialising database configure table....
2015-02-27 15:10:54 [1863509792] Info: Database environment...
2015-02-27 15:10:54 [1863509792] Info: logging_level::2
2015-02-27 15:10:54 [1863509792] Info: proxy_hostname::DomainName.co.uk
2015-02-27 15:10:54 [1863509792] Info: proxy_port::25
2015-02-27 15:10:54 [1863509792] Info: mta_hostname::
2015-02-27 15:10:54 [1863509792] Info: mta_port::26
2015-02-27 15:10:54 [1863509792] Info: web_hostname::mail.DomainName.co.uk
2015-02-27 15:10:54 [1863509792] Info: web_port::4044
2015-02-27 15:10:54 [1863509792] Info: DatabaseManager::UpgradeDatabase - version 32 ok
2015-02-27 15:10:54 [1863509792] Info: Open database....
2015-02-27 15:10:54 [1863509792] Info: Initialising database white listing table....
2015-02-27 15:10:54 [1863509792] Info: Initialising database black listing table....
2015-02-27 15:10:54 [1863509792] Info: Initialising database filter black listing table....
2015-02-27 15:10:54 [1863509792] Info: Initialising database filter white listing table....
2015-02-27 15:10:54 [1863509792] Info: Initialising database rbl listing table....
2015-02-27 15:10:54 [1863509792] Info: Initialising database quarantined table....
2015-02-27 15:10:54 [1863509792] Info: Initialising database gray listing table....
2015-02-27 15:10:54 [1863509792] Info: Initialising database white listing ip table....
2015-02-27 15:10:54 [1863509792] Info: Initialising database black listing ip table....
2015-02-27 15:10:54 [1863509792] Info: Initialising database user table....
2015-02-27 15:10:54 [1863509792] Info: Initialising database Gray listing friends table....
2015-02-27 15:10:54 [1863509792] Info: Initialising database Domain table....
2015-02-27 15:10:54 [1863509792] Info: Initialising database stat tables....
2015-02-27 15:10:54 [1863509792] Info: Initialising database delivered table....
2015-02-27 15:10:54 [1863509792] Info: Initialising database trusted ip table....
2015-02-27 15:10:54 [1863509792] Info: Initialising database track table....
2015-02-27 15:10:54 [1863509792] Info: Initialising License Manager....
2015-02-27 15:10:54 [1863509792] Info: Initialising WebManager....
2015-02-27 15:10:54 [1863509792] Info: Starting StatThread....
2015-02-27 15:10:54 [1863509792] Info: Starting DigestReportThread....
2015-02-27 15:10:54 [1863509792] Info: Starting FilterManagerThreads....
2015-02-27 15:10:54 [1838249728] Info: Starting TaskThread....
2015-02-27 15:10:54 [1543501568] Info: Checking authentication
2015-02-27 15:10:54 [1863509792] Info: Started MTA proxy....
2015-02-27 15:10:54 [1863509792] Info: Starting HouseKeepingTask....
2015-02-27 15:10:54 [1863509792] Info: Initialising Auto-reporting....
2015-02-27 15:10:54 [1863509792] Info: ShutdownTime::42061.923854, CurrentTime::42062.632569, Clock::0.708715
Sat Feb 28, 2015 7:32 am
Dave, can you go to Settings>>Action, and change the logging level to 'High' then run it again and post back to the logs. That will give us much more info.
DaveWilliamson
Sun Mar 01, 2015 2:04 am
Here is what they have sent so far, I have asked for a much more detailed log.
root@968931 [~]# /etc/init.d/mwesd status
Mailwasher Enterprise Server is running
Please find the below snippet for log details,
2015-02-28 12:42:27 [2471520032] Info: Starting HouseKeepingTask....
2015-02-28 12:42:27 [2471520032] Info: Initialising Auto-reporting....
2015-02-28 12:42:27 [2471520032] Info: ShutdownTime::42063.047465, CurrentTime::42063.529479, Clock::0.482014
2015-02-28 12:42:27 [2116011776] Debug: Connect to URL (209.213.221.170)...
2015-02-28 12:42:27 [2116011776] Debug: Successfully Connected to URL (209.213.221.170)...
2015-02-28 12:42:27 [2116011776] Debug: VersionStatus::Collect - xml size(173)
<mwes>
<VersionNumber>2.8.1.4</VersionNumber>
<VersionURL>http://www.firetrust.com/en/products/ma ... VersionURL>
</mwes>
DaveWilliamson
Sun Mar 01, 2015 10:02 am
I have had to ditch the hosting company I was going to use as they have now refused point blank to help any further with trying to get mailwasher working. The problems what they have come up with go from not enough memory to not having enough space and then they just turned around and said
"Upon checking we could not find any issue for the server. Server running fine.
Unfortunately, we can't to do anthing more eregarding the mailwasher . We can't provide more support for 3rd party softwares. "
So they are blaming the software rather then them not been able to get it installed, the company is - planethippo.co.uk (name and shame them, what the hell)
DaveWilliamson
Sat Mar 14, 2015 2:46 am
Anyone know why mail when rescued from quarantine does not go to the mail email address it was meant for ?
Sat Mar 14, 2015 9:10 am
It should rescue to the recipients email address, unless there's some redirection with the mail server.
DaveWilliamson
Sun Mar 15, 2015 1:37 am
Anything is possible with this new company.
New one ready that they have not touched other then putting cPanel on CentOS 6 on.
Return to “Linux Specific”
