Email Is Not Configured Propertly
Duck
Tue Mar 24, 2015 7:40 am
Wow...just when I thought I had seen everything...
When I open Mailwasher Pro (ver. 7.5) and click on REPLY to reply to an email WITHOUT processing it through MWP, IE continues to open browser windows until I have to reboot! NOTHING stops this from happening and I am able to duplicate it with ease. I don't even use IE (I'm a Firefox man) so this is even more perplexing. I have checked for malware and I have no other issues except with how MWP replies from within. I usually just wash the mail and reply from within, but since I have emails on more than one computer, I like to reply from within until I can get back on my main computer.
Any thoughts?
Duck
Re: Email Is Not Configured Propertly
Tue Mar 24, 2015 12:32 pm
It's your MailTo settings:
Control Panel\All Control Panel Items\Default Programs\Set Associations
Select MaiTo and set it up the way you want.
Duck
Wed Mar 25, 2015 8:59 pm
Sidewinder wrote:It's your MailTo settings:
Thanks Sidewinder,
That did not work as I had already had it set up. I just did a reinstall and that seems to have fixed the problem for now. Something must have gotten corrupted along the lines. MWP is an awesome program!!! Thanks for the suggested fix.
Duck
Duck
Tue May 12, 2015 1:42 pm
Well, I "thought" that I had fixed this problem when trying to reply to emails from withing MWP. However, I still had the problem of dozens and dozens of IE windows opening (even though I was using Firefox)! The exact error that I got was: "Could not perform this operation because the default mail client is not properly installed". I ONLY got this from replying from within MPW...no other programs caused this.
I finally got fed up with CTRL ALT DEL attempts to close all of those IE windows! I found this page: http://web4.uwindsor.ca/its/faq/id/534 and I used the .reg and it totally fixed my issue. So...if anyone else has this problem, here ya go! I hope that it helps.
Duck
ataraxy
Tue May 12, 2015 8:26 pm
Thanks for reporting back!
Windows 10
Tue May 12, 2015 11:21 pm
Great find! :thumbsup :thumbsup :bow :bow
Thanks for sharing!
