Problems with the "All Web Browsers" rule.
AnthonyJAttard
Fri Jul 24, 2015 7:19 pm
Sometimes this rule seems to stop Firefox from getting to any web-site. It just times out. But when the rule is disabled everything goes back to normal. Then I reactivate the rule and the browser works properly.
Also there seems to be a problem with Visual Studio 2015 Community Edition. I could not login to my MS account until I unloaded HideAway.
Other than this little annoyance, it seems to work well.
Re: Problems with the "All Web Browsers" rule.
Fri Jul 24, 2015 7:57 pm
Hi there
You are using version 1.3.1 ? You can check that under Help.
I'll install Visual Studio 2015 Community Edition now, see if can get that reproducing, will get that done later tonight.
We do have a problem with the server not always resending dropped packets properly, there is a fix in the works for that to rollout on the servers. We're hoping mid August to get that in place, which ought to correct the problems you are seeing in Firefox.
rd
