Mailwasher running on Vista Business
agcohio
Wed Sep 03, 2008 5:42 am
Is there a way to permanently give permission to Mail Washer to run on Vista. I have turned off the user permission. Still every time the computer boots up, it says that Mail Washer has been stopped from running automatically. Even if I do not put MailWasher 6.2 into startup and just start after Vista is running, it always asks for permission to run.
Re: Mailwasher running on Vista Business
Wed Sep 03, 2008 9:53 am
It sounds like you are running MailWasher as Admin, perhaps you set this previously when the earlier versions weren't working so well with Vista. If you right click the MailWasher shortcut >> go Properties >> uncheck "Run this program as administrator".
