Problem syncronising Android
kenuk
Thu Oct 22, 2015 11:50 pm
I downloaded your app for Android and after I realised I needed a different password I thought I had it sussed! However, when I open Mailwasher Pro on my desktop and try to sync the accounts I got this message:
{"code":1000,"message"":Validation Failed","errors":[{"code":2030, "field":"email","message""Unique key violation"}]}
Re: Problem syncronising Android
Fri Oct 23, 2015 6:28 am
Hi
Can you (in MailWasher Pro), go to Settings>>Accounts>>General, and remove any non letters from the 'Account Description' such as apostrophes ' and brackets () etc.
Then try to sync again.
