Nexus 7
Parbuster
Nexus 7
Mon Feb 01, 2016 6:48 am
Why am I always asked to sign in and why will my sign in for Mailwasher not work on my tablet???????
Re: Nexus 7
Mon Feb 01, 2016 7:01 am
Hi
Sorry, it's a problem with this version. When you lose connectivity it will sign out.
Bendo
Re: Nexus 7
Tue Mar 07, 2017 1:15 am
I am facing this issue. However, my device is still connected but its showing me that I've signed out.
Re: Nexus 7
Tue Mar 07, 2017 7:11 am
If it loses connectivity briefly while MW is being used then you'll have this issue
Bendo
Re: Nexus 7
Tue Mar 07, 2017 9:08 pm
Like even if I move slightly away from the range it will loose connection?
Re: Nexus 7
Tue Mar 07, 2017 9:15 pm
Well, it's if you phone loses connection, that's the issue. Something we need to fix
Bendo
Re: Nexus 7
Thu Mar 16, 2017 4:00 am
Alright. I'll get my phone checked too, though I doubt it has connection problem
Re: Nexus 7
Thu Mar 16, 2017 6:34 pm
It wont' be your phone problem, if it loses a connection - ie goes out of the area for example then MWM will logout if it's in use.
Bendo
Re: Nexus 7
Tue Mar 21, 2017 8:47 pm
No. I don't go out of the range completely. This is what I was saying before. The connection is there but the program goes offline. That's the issue mate.
Re: Nexus 7
Tue Mar 21, 2017 9:34 pm
Ok, we'll see if we can reproduce - but it's pretty hard to fix if we can't reproduce it. More likely a fix for the connection dropping would fix this too
Bendo
Re: Nexus 7
Tue Mar 28, 2017 3:45 am
I'll search for that too! Thanks for responding so swiftly!
Bendo
Re: Nexus 7
Wed May 31, 2017 11:15 pm
this issue is still happening.
Re: Nexus 7
Thu Jun 01, 2017 5:35 am
Yes, hasn't been fixed yet
Bendo
Re: Nexus 7
Mon Jun 05, 2017 4:42 pm
Any suitable timeline that you can provide me?
Re: Nexus 7
Mon Jun 05, 2017 8:37 pm
We're actually re-doing MailWasher, which also works as an email client.
