Using a country to automatically select the best server
gunzelguy
Sun Apr 24, 2016 12:32 am
Is it possible to just select a country to make a rule that the best server in that country is automatically selected, rather than specifying the server location city?
Re: Using a country to automatically select the best server
Wed Apr 27, 2016 7:50 pm
It's not able to be done at the moment, but thanks for the suggestion. At the moment if you select 'Auto' it will select the closest server in that location based on ping. But it might be more useful to select by country as you suggest. Thanks
