No MTA found on port 26. Please fix this then re test
jesper
Tue Apr 26, 2016 10:24 pm
I have try to install the MailWasher SERVER 3.0.0.6 {U64} but i can not get the SMTP and mta to work! I get failed. I run this in a new install ubuntu 14.04 LTS 64-bits.
In my log file i have this
2016-04-26 11:46:05 [1166960512] Info: ShutdownTime::42486.484363, CurrentTime::42486.490336, Clock::0.005973
2016-04-26 11:46:13 [2524956416] Error: SMTPChannel::ConnectToRelay - SocketException - TCPSocket::Connect - connect :: failed with code 111: Connection refused :: failed with code 107: Transport endpoint is not connected
2016-04-26 11:46:13 [2524956416] Error: SMTPChannel::ObjectThreadMethod - SMTPChannelException - SMTPChannel::Welcome - No MTA server available
2016-04-26 11:46:13 [2541741824] Error: Check::DoMTACheck - StdException - TCPSocket::Connect - connect :: failed with code 111: Connection refused :: failed with code 107: Transport endpoint is not connected
2016-04-26 11:46:28 [2541741824] Error: SMTPChannel::ConnectToRelay - SocketException - TCPSocket::Connect - connect :: failed with code 111: Connection refused :: failed with code 107: Transport endpoint is not connected
2016-04-26 11:46:28 [2541741824] Error: SMTPChannel::ObjectThreadMethod - SMTPChannelException - SMTPChannel::Welcome - No MTA server available
2016-04-26 11:46:28 [3045041920] Error: Check::DoMTACheck - StdException - TCPSocket::Connect - connect :: failed with code 111: Connection refused :: failed with code 107: Transport endpoint is not connected
anyone that can help me?
And yes, i sure that no ports are in used now today.
Re: No MTA found on port 26. Please fix this then re test
Wed Apr 27, 2016 7:24 am
Hi
What Mail server/MTA are you using? Have you changed your mail server/MTA port to listen on port 26?
