Testing Encryptus
Troubleshooting and help for Encrypt
watsonm
Testing Encryptus
Fri May 20, 2016 8:46 pm
Just downloaded and installed Encryptus. How do I test that it is indeed encrypting an e-mail.
Cheers Mike
ataraxy
Re: Testing Encryptus
Sat May 21, 2016 3:41 am
The easiest way is to set up a second account and send an email from one account to the other. Then check the email in web mail. If it's been encrypted, the encrypted text won't be visible.
Note that to send between accounts, as well as setting up the accounts on the Email Accounts tab, you also need to add them on the Contacts tab.
As far as I know, v1.1.8 is still a beta version, so feel free to report back on how you go.
Windows 10
