Changed ip address now cannot get on the web Program
gene_acres
Sat Jun 18, 2016 6:56 am
I changed the ip address today on the mail server. I can no longer get on the web configuration program. I guess I should have changed the ip on the hostname first. Is there a way to edit the script file and change the ip address on the hostname so I can configure my mail washer?
Gene Lucas
Re: Changed ip address now cannot get on the web Program
Sat Jun 18, 2016 9:04 am
You can change this setting in the 'configure' table of the MWES database (mwes.db)
There's a couple of easy ways to access the database.
1. Get the free http://www.sqliteexpert.com/download.html and navigate to the configure table.
2. Navigate to the installed program directory and locate mwes.db, then navigate to the configure table.
Database location
Windows: C:\Program Files\MailWasher Enterprise Server\data
Linux: \opt\mwes
Windows If changed, restart the MailWasher Enterprise Server Service (Go to Start>>Run>>Type 'services.msc' and locate MailWasher Enterprise Server, and restart).
Linux users If changed, restart service/daemon.
Database location
Linux: \opt\mwes
gene_acres
Sun Jun 19, 2016 10:45 am
