Auto enable/disable a rule on a known WiFi
FransL
Sat Jun 18, 2016 8:36 pm
What
Please consider to include the option in the HideAway rule setting that a rule may be automatically enabled/disabled upon being connected to a known WiFi
Why
When I am on my 'home' network, traffic does not require to be rerouted however and especially when I am abroad, HideAway should always reroute.
How
Add 'auto enable a rule checkmark' and a whitelist that overrides the auto setting and auto disable the rule
Add 'auto disable a rule checkmark' and a blocklist that overrides the auto setting and enable the rule
Re: Auto enable/disable a rule on a known WiFi
Tue Jun 21, 2016 4:27 pm
This is a nice idea. We'll need to figure out if we can check which network interface information and then yes, it should be doable. Makes it a nice hands off tool.
