112.002 growing up files under crypto folder
webmood
Tue Aug 02, 2016 8:46 pm
Dear All,
Under C:\Users\*******\AppData\Roaming\Firetrust\MailWasher\cache\crypto there are 112.002 files and they're constantly growing up. Nothing bad, but doing backups is taking too much time. Please, is there any safe way to reduce the number of files in crypto? Thank you!
Kind Regards,
Emanuela Bechi
Florence - Italy
Re: 112.002 growing up files under crypto folder
Tue Aug 02, 2016 10:28 pm
Under Setting >> Accounts >> Incoming >> click the Advanced drop down >> remove the check mark from removed cached emails. You can do this for each account.
Also under Settings >> Recycle Bin >> General >> you can reduce the amount of days MailWasher stores the deleted emails for.
After making those changes, restart MailWasher, though it may take up to 24 hours for the routine maintenance to clean things up.
webmood
Wed Aug 03, 2016 9:34 am
rusticdog wrote:Under Setting >> Accounts >> Incoming >> click the Advanced drop down >> remove the check mark from removed cached emails. You can do this for each account.
More than perfect. Thank you indeed!
schnief
Guardian Gecko
Location: How can you be in two places at once when you're not anywhere at all?
Tue Mar 20, 2018 11:21 pm
rusticdog wrote:Under Setting >> Accounts >> Incoming >> click the Advanced drop down >> remove the check mark from removed cached emails. You can do this for each account .....
Ummmm, the only thing I see is "Store cached mails". Is that what you meant?
MWP on Win7 SP-1 x64 (English) on two Lenovo S20s (a Xeon X5675 w/18gb RAM and a Xeon x5670 w/12gb RAM; the same OS is also on 3 laptops). I also have MWP on two Win 10 x64 machines (German) and one with XP Pro-SP3 32-bit (English).
Wed Mar 21, 2018 6:54 am
Yup, that's it.
schnief
Guardian Gecko
Wed Mar 21, 2018 8:19 am
rusticdog wrote:Yup, that's it.
OK, Chris. Thanks.
Best regards,
Joe
