Hideaway 1.4.0 & Windows 10 Anniversary Update
bgarries
Tue Sep 13, 2016 1:40 am
Hi.
I installed the Windows 10 Anniversary update over the weekend and now Hideaway 1.4.0 crashes every time it's started. I looked at Uninstalling/Reinstalling but it no longer shows as an installed program on my system. I tried a simple reinstall without uninstalling but nothing changed, it still crashes immediately.
Tried the 2.0 Beta using Internet explorer and routing through London so I could get to ITV and it would did nothing when I hit the play button. Changed it to All of the Computer and London and I can now access ITV.
Finally, since Sept 1, apparently you need a TV license in order to access the BBC iPlayer. I'm guessing that this change will stop us from using Hideaway to access this site.
Brent
Update: The install without doing the uninstall put Hideaway in a position that it was not recognized as an installed program. I uninstalled and reinstalled it and it's working fine now.
Update 2: Spoke too soon. Hideaway 1.4.0 just crashed again.
Re: Hideaway 1.4.0 & Windows 10 Anniversary Update
Tue Sep 13, 2016 12:57 pm
Hi there
Seems to be an issue when Windows 10 updates itself, something we're trying to work out - but appears to be related to our certificate for the driver we use.
If you uninstall, you need to restart windows, then install 1.4 again and restart Windows for it to work.
When asked if you have a TV license, if you say Yes, then they don't check it. It won't affect you watching BBC iPlayer if you want to.
bgarries
Wed Sep 21, 2016 10:24 pm
Thanks for the information, Nick.
Never would have thought to just say that I had a license, but it works fine now.
Cheers.
ajwnet
Sat Oct 01, 2016 6:02 am
Also just installed the Windows 10 nniversary update (in the last few minutes) and Hideaway is logging me in,but failing to load my rules - a JavaScript Alert pops up as attached. Thanks in advance guys. :)
ajwnet
Sat Oct 01, 2016 9:24 am
Update to that : tried uninstalling Hideaway, rebooting windows, reinstalling Hideaway - same problem...
Final update - reinstalled again - reboot - it works!!
Many thanks to whoever tweaked the server at your end :)
