Installation POP problem
r.beatley
Tue Sep 16, 2008 1:34 am
When I click the Check Mail Button I get the following "The authentication failed for POP.ntlworld.com (POP.ntlworld.com) Bad username or password" The username is already entered, I cannot remember having a password for POP.ntlworld and everything I try fails, can anyone help please?
Re: Installation POP problem
Tue Sep 16, 2008 2:15 am
Contact your ISP and have them reset your password for you. POP has to use a password or anyone could read and delete your e-mail.
Tue Sep 16, 2008 5:02 pm
Moved into MW Troubleshooting...
r.beatley
Wed Sep 17, 2008 12:57 am
stan_qaz wrote:Contact your ISP and have them reset your password for you. POP has to use a password or anyone could read and delete your e-mail.
Many thanks for your help, problem solved Cheers ray
r.beatley
Wed Sep 17, 2008 12:59 am
rusticdog wrote:Moved into MW Troubleshooting...
Many thanks for your help, problem solved Ray
