SMTP Banner & SSL
Address problems with the installation and initial configuration
jojodadj
SMTP Banner & SSL
Tue Dec 20, 2016 5:43 am
Hi There,
Is there a way to change the SMTP banner so that it matches with out Reverse DNS?
Is there anyway for Mailwasher to support TLS?
Joe
Re: SMTP Banner & SSL
Tue Dec 20, 2016 12:34 pm
If you can change your MTA FQDN message then MWES can use that instead.
You'll need to add this in to the Windows Registry or Linux conf file
use_mta_connection_message=1
Windows Registry: HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\Firetrust Limited\mwes
Linux: \etc (mwes.conf)
Restart MWES service/daemon after changes.
At the moment it can't support TLS because it works as a proxy, but it's something we have planned to implement.
Return to “Installation”
