Mailwasher (NOT RESPONDING) 6.5.4
angelah
Mon Feb 20, 2017 5:21 am
Hello all -
I posted in Dec. that every time I opened MW 6.5.4 it gave me a "not responding" message. The always helpful forum guru, RusticDog, gave me the below solution which worked Temporarily.
Hi there
Try going into Help >> About >> open the link to where MailWasher stores the data files >> then close MailWasher so it's not running >> back in the folder you just opened rename the Training folder to something like TrainingOLD >> restart MailWasher.
Now I'm back to this issue about 10x per day, and always have to restart MW about 4x before it opens properly. Seem to be having the same probable with Outlook Professional 2013. Suggestions?
THANK YOU IN ADVANCE!
Re: Mailwasher (NOT RESPONDING) 6.5.4
Mon Feb 20, 2017 10:00 am
Angelah, would suggest backing-up your copy, rebooting the system, cleaning out the debris and then adding back your accounts — in other words, starting from scratch on a completely new slate. :idea:
I know that's going to be a bit painful. :(
MWP 7 (ßeta) | Windows 10 LTSC (21H1) | The Bat! Professional (ßeta) | Windows 10 Firewall Control (ßeta) | ESET Endpoint Antivirus (ßeta) | nVIDIA GeForce (GTX 1060) | Internet Connection Speed (4G USB tethering — VoLTE) | .NET Framework (4.8)
angelah
Mon Feb 20, 2017 11:46 am
UGH....nooooooo. I have 5 accounts on it it will take a lifetime. A ton of blacklisted spammers. Something? anything? other than a reinstall?
Mon Feb 20, 2017 4:00 pm
You could try renaming your Trash.rot135, so the same steps just rename the Trash file (which is the Recyle Bin)
Hi there
Try going into Help >> About >> open the link to where MailWasher stores the data files >> then close MailWasher so it's not running >> back in the folder you just opened rename the Trash.rot135 file to something like OLDTrash.rot135>> restart MailWasher.
angelah
Fri Feb 24, 2017 6:20 am
Hi, Thanks so much for the reply, rusticdog. Oddly, I can't find Help About, now....do I find that on the program or C drive? Thanks again
angelah
Fri Feb 24, 2017 6:39 am
Cancel request, Rusticdog....I found it.
