mail not showing
salty
mail not showing
Mon Feb 20, 2017 11:08 pm
when I click on check mail......my spam does not appear. I know I have 10 spam in folder. My settings are
pop3
pop.gmail.com
Myemailname@gmail.com
password for gamil
server port - 995
SSL ticked
use oauth ticked
pipelining both ticked
why is my spam not showing when I click on check mail......help please..
Re: mail not showing
Mon Feb 20, 2017 11:34 pm
If I recall, with POP and GMail you need to tell GMail not to move spam messages into the Spam folder, that way they'll display in your Inbox, which is what MailWasher checks.
Details on how to do that can be seen here http://webapps.stackexchange.com/questi ... completely
Mon Feb 20, 2017 11:54 pm
Graphic illustration here (if required.)
It's quite an old post — you might need to use just a little bit of improvisation. ;)
salty
Tue Feb 21, 2017 12:18 am
rusticdog wrote:If I recall, with POP and GMail you need to tell GMail not to move spam messages into the Spam folder, that way they'll display in your Inbox, which is what MailWasher checks.
just moved the 5 spam to inbox and the mailwasher did pick them up......thanks
salty
Tue Feb 21, 2017 12:20 am
just moved the 5 spam to inbox and the mailwasher did pick them up......thanks BUT when I check my trash folder the 5 spam are there...is this correct? Mailwasher does not get rid of them completely....
Tue Feb 21, 2017 7:24 pm
salty wrote:just moved the 5 spam to inbox and the mailwasher did pick them up......thanks BUT when I check my trash folder the 5 spam are there...is this correct? Mailwasher does not get rid of them completely....
Well, MWP does rid of the spam from the Gmail Trash folder, too — if you tell it to.
salty
Tue Feb 21, 2017 9:31 pm
Interseted....how and where do I tell it to get rid of the spam from the trash folder....thanks
salty
Wed Feb 22, 2017 2:12 am
Interested....how and where do I tell it to get rid of the spam from the trash folder....thanks
lord239
mail wash
Mon Jul 31, 2017 8:19 pm
mail wash icon not lighting up
