I've just installed HideAway 3.0 and it has installed in AppData.
Is this correct? Does this mean that I have to do a separate install for every user?
HideAway 3.0 - Installation process
Re: HideAway 3.0 - Installation process
Yeah it would mean installing for each wanted. If I understand it right, the driver installs system wide but the UI (so later on the rules etc..) will be user specific
- ataraxy
- Knowledgeable Kea
Thanks.
Sounds like a very roundabout way to do it. Can't we just have a normal installation and the user data control the rules and so on?
And just for the record, updates appear to work as I already have v3.0.1, though it appears that you need to log off and log on again in order for the update to be applied.
Windows 10
