3.0 Install Fail
watsonm
3.0 Install Fail
Thu Mar 30, 2017 5:18 am
Been trying to Install 3.0.1 (and 3.0.0) and constantly get a failure of the driver install code.
Have uninstalled previous version and rebooted umpteen times.
Tried running installer as administrator still no luck
Driver install failed 4294967295 message Command Failed
C:\\ users....... \app-3.0.1\resour..\HideAwayDriverSetup.exe --install
Thanks for any help
Windows 10 64bit
Re: 3.0 Install Fail
Thu Mar 30, 2017 5:25 am
What happens if you try installing in Safe Mode?
watsonm
Thu Mar 30, 2017 6:45 am
TrustFire wrote:What happens if you try installing in Safe Mode?
It doesn't even attempt to install.
Few seconds of "working circle" and then silence!
watsonm
Thu Mar 30, 2017 6:53 am
Not sure if it's relevant but in the drivers directory there is just the exe file and no driver file.
(ie one I recognize as a driver .sys .inf ) unless it is embedded in the exe
Thu Mar 30, 2017 8:14 am
Are you able to run the program by double clicking HideAway.exe which (in your case) might reside at either of the following directories:—
  • Code: Select all
    C:\Users\YourUserName\AppData\Local\HideAway\app-3.0.1
    Code: Select all
    C:\Users\YourUserName\AppData\Local\HideAway\app-3.0.0
Thu Mar 30, 2017 11:57 am
Hi, can you please try this
1. Command Prompt (Run as Administrator)
2. `cd %LOCALAPPDATA%\HideAway\app-3.0.1\resources\driver`
3. `HideAwayDriverSetup.exe -u` (to uninstall, will need restart)
Then run HideAway clicking "Yes" if UAC is On.
If that still fails, repeat Step 1 and 2 but instead type:
`HideAwayDriverSetup.exe -i` (to install, and screenshot please)
FransL
Thu Mar 30, 2017 10:20 pm
watsonm wrote:Been trying to Install 3.0.1 (and 3.0.0) and constantly get a failure of the driver install code.
Same here
IMHO it is a programming error when the installation path contains 'spaces'.
Spaces are not handeled correctly and HideAway installs with a 'non existing' path.
watsonm
Fri Mar 31, 2017 12:03 am
TrustFire wrote:Are you able to run the program by double clicking HideAway.exe which (in your case) might reside at either of the following directories:—
  • Code: Select all
    Code: Select all
That produces the same error with an extra line...
registerDriverr (-1) unknown error
watsonm
Fri Mar 31, 2017 12:16 am
nick.bolton wrote:Hi, can you please try this
Now that surprised me.
I did the uninstall and reboot.
Then I thought why is he asking me to click on Hiedaway if I have just uninstalled it!!
But doing so and 3.0.1 worked!!!!!!!!
Many thanks for your help
smart1960
Fri Mar 31, 2017 6:18 am
Have you tried running this as "ADMINISTRATOR"? I had this problem and after the fix sent by Chris ran as ADMIN and it did what it should do. :D :D
watsonm
Fri Mar 31, 2017 7:19 am
smart1960 wrote:Have you tried running this as "ADMINISTRATOR"? I had this problem and after the fix sent by Chris ran as ADMIN and it did what it should do. :D :D
Cheers, I believe i said I tried that in the original post .
Fortunately Nick's post fixed the issue.
FrancesBur
Thu Oct 12, 2017 2:21 am
When I right click on it there is no run as admin button. How do you run as admin?
Thu Oct 12, 2017 7:54 am
Just right click on the file, a menu will pop up, choose 'Run as administrator'
Thu Oct 12, 2017 10:51 am
In case your Run as administrator context menu is truly missing, you can restore it by downloading and then merging the following entry into your registry (by just running it):—
