Mailwasher 7.9.0 Not Deleting Emails at Server within Mailwasher Program
Norman_24
Tue May 09, 2017 6:07 am
Mailwasher Pro is not deleting the emails when I click the delete tab and wash the email, they still are being d/l onto my pc, any ideas??? It's been doing this since the last update I believe... And they don't auto-delete from the program unless I do a check mail again...
Thanks,
Norman
Re: Mailwasher 7.9.0 Not Deleting Emails at Server within Mailwasher Program
Tue May 09, 2017 11:01 am
Unfortunately, you have posted at the wrong forum. I don't think you will find any response in this section. :no
You may want to re-post at either of the following forums as per your flavor of MWP:—
ps:—
    For a quick resolution, you may also want to post the description of your e-mail client/s and e-mail service and also whether you are using POP3 or IMAP on MailWasher and your client/s, as well.
Norman_24
Wed May 10, 2017 6:17 am
My apologies and thank you for the info....
Bendo
Mon Jun 05, 2017 5:24 pm
I also had this issue with the mailwasher, but I believe it got solved with the last update.
