MWESD does not work after upgrade to MWES64-3017
Problems/tips/tricks with MailWasher Enterprise and Linux
cwh168998
Tue Aug 15, 2017 7:39 am
mail.log
(407.03 KiB) Downloaded 646 times
The error is:
2017-08-14 10:22:56 [1442821888] Error: TrackTable::RemoveByDate - failed - SQLite Error: sqlite3_exec returned error code: 11 error message: database disk image is malformed
Re: MWESD does not work after upgrade to MWES64-3017
Tue Aug 15, 2017 7:44 am
Hmm, seems it failed around midnight. Did you do a backup around that time or antivirus scan? Housekeeping in MWES now runs continuously so I'm wondering if the database was corrupted while it was backed up/scanned? Do you have a backup of the database you can use, and then next time ignore it for backup or scan?
Return to “Linux Specific”
