Kaspersky Internet Security 2018
Jancux
Mon Nov 27, 2017 3:32 am
Kaspersky Internet Security 2018 stops Hideaway from working!
I have had to revert to KIS 2017.
Can you advise me, and others, how to to configure KIS 2018 to allow Hideaway to work.
Re: Kaspersky Internet Security 2018
Mon Nov 27, 2017 8:05 pm
Did you install KIS 2018 after installing HideAway ?
I wonder if reinstalling HA after installing KIS 2018 would work. I assume too they did not correct the issue with the network driver failing to install correctly if Self Defence was enabled under Settings >> Additional >> Self Defence.
Jancux
Mon Nov 27, 2017 9:12 pm
I have already tried uninstalling and reinstalling Hideaway after the Kaspersky update.
It makes no difference!
Since your introduction of the new software there is no longer a conflict on uninstalling between Kaspersky and Hideaway!
Regards
Jancux
Mon Nov 27, 2017 11:26 pm
OK, just installed KIS 2018 and it appears like HA is running for me. Can you elaborate on an action/service you were trying. Feel free to email me instead at forum@firetrust.com
