Cox Cable new settings causing problems with MailWasher 6.5.4
Thelma Wickwere
Tue Jan 30, 2018 5:06 am
Any other users having a problem with the new Cox Cable settings and MailWasher? MailWasher will time out, with a notice saying "no response received from the server". Any suggestions greatly appreciated!
Re: Cox Cable new settings causing problems with MailWasher 6.5.4
Tue Jan 30, 2018 10:51 am
Hi there
What were the changes that Cox made to the settings ?
Thelma Wickwere
Tue Jan 30, 2018 12:08 pm
Thank you, RD. I've attached four screen shots to show the steps and settings Cox required. Appreciate any help you can provide!
Capture settings.JPG (57.59 KiB) Viewed 7863 times
Capture settings1.JPG (88.32 KiB) Viewed 7863 times
capture settings2.JPG (69.31 KiB) Viewed 7863 times
Capture settings3.JPG (60.51 KiB) Viewed 7863 times
Tue Jan 30, 2018 12:25 pm
OK, so in MailWasher, it looks something like this ?
Thelma Wickwere
Tue Jan 30, 2018 7:45 pm
Yes, settings do now look like that in MailWasher. I deleted the account and then re-entered it manually, using those settings and it seems to be working ! Wow, I really appreciate your help so much. RusticDog, you are a treasure.
Tue Jan 30, 2018 7:55 pm
Great, glad it's all sorted now.
rd
dearwebby
Sat Mar 10, 2018 3:33 pm
If you use Eudora, Cox.net won't let you have your email or even look at it with MailWasher. No matter how much you love Eudora, you have to change to Thunderbird.
It is not the fault of MailWasher, but of Cox.net.
Have FUN!
DearWebby
