Microsoft One Note
Dels
Microsoft One Note
Wed Apr 18, 2018 10:03 am
I have recently started to see Microsoft One Note opening up when I press the Check Mail button in Mailwasher!
It does not happen consistently BUT it is always triggered by Mailwasher manually checking mail or beginning the washing process.
I was wondering if anyone else has experienced this? It is an odd problem!
Cheers,
Dels
Re: Microsoft One Note
Wed Apr 18, 2018 11:01 am
Well, that's a new one.
My first thought is to run a .NET Repair. That has a habit of fixing up the really quirky issues.
You can download the utility from https://www.microsoft.com/en-nz/downloa ... x?id=30135
Run this, follow the on screen steps, reboot afterwards just to be safe. Can take around 10-15 minutes.
If that doesn't do it :
Is "Send To One Note" set as your default printer ? And if so, try and set another default. I say this only because that's what this guy said
https://answers.microsoft.com/en-us/off ... d90f0d94fb
There is this post too about resetting One Note, but I would see how above goes first before tinkering
https://answers.microsoft.com/en-us/mso ... 01a78db79c
