Why's everything suddenly white?
cmhmd
Sat Apr 28, 2018 9:51 am
I've been using MWP for a couple years now, diligently thumbing up and down and seemed to be doing pretty well.
Suddenly this past week, nothing seems to be sorting - everything is white and I'm stuck starting all over sorting things.
What happened?
Thanks, in advance for your help.
CMHMD
Re: Why's everything suddenly white?
Sat Apr 28, 2018 10:31 am
What version MailWasher are you using ?
For everything to go back white would mean the Learning has been reset. Data loss would also do that, MailWasher stores the information in a database and also in flat files, under Help >> User Files >> cache (for MW 7)
