MailWasher Free Stopped Downloading Emails
RicRat
Thu May 03, 2018 3:53 pm
I have been using MW Free for several years and it has always worked great.
Recently, MW has stopped downloading emails. At first I was getting Unknown Error message.
Now it will check emails, find 26, but will only download one at a time. Each time I click check mail, it downloads another. It also takes several minutes to download the one email. It sits at, "found 26 messages (total 26)", then it finally changes to "downloading 3 of 26", and downloads one more, and so on.
I have unckecked Pipelining and Store cached emails. It has made no difference.
I uninstalled and reinstalled, it did not fix the issue.
Here is the error I get at times.
Diagnosis: <EVENT><NAME>MWPEXCEPTION</NAME><ID>264094fb78a64a4378f56763cebaea83</ID><DT>2018-05-02 22:35:12</DT><MWPEXCEPTION><UID>Exception 9e8d81aabfefca78d5c2270160305c60</UID><AID>Acct-654821619</AID><SOURCE>MWPfetch::FetchThread()</SOURCE><MESSAGE>Unknown error</MESSAGE><ADDXML></ADDXML></MWPEXCEPTION><ORDINAL>0</ORDINAL></EVENT>
Re: MailWasher Free Stopped Downloading Emails
Thu May 03, 2018 3:56 pm
Hi there
Flick me some logs. Go Help >> Send Support Logs >> enter a brief note like 'not downloading' >> in the Ticket Number field enter chris >> Send Logs.
Reply back once sent, so I know to be on the lookout for them.
Chris
Thu May 03, 2018 3:59 pm
Just to add, this very much sounds like the PIPELINING may still be enabled, so just be sure that is disabled for all accounts when Checking Mail.
RicRat
Thu May 03, 2018 4:02 pm
Thanks, sent just now.
Confirmed Piplining is unchecked.
Thu May 03, 2018 4:16 pm
OK, not seeing them, that's OK, instead if you go into Help >> User Files >> look for autosupport.eml and if you can send me that as an attachment to forum@firetrust.com
RicRat
Thu May 03, 2018 5:29 pm
Autosupport file sent.
Thu May 03, 2018 5:51 pm
It looks like it might be an email MW doesn't like.
First thing I would try, under Settings >> Accounts >> Incoming >> change your server address to mail.twc.com >> click Advanced >> check the option "This server requires a secure connection (SSL)" >> Save. This is just to get your settings in line with what's recommended and added SSL is a more secure connection.
https://www.timewarnercable.com/en/supp ... esses.html
When you use mail.twc.com you also need to be sure your username if your full email address, you already have that now, just mentioning it just in case.
If that doesn't work, try removing the account >> restart MailWasher >> then add the account back.
RicRat
Thu May 03, 2018 6:01 pm
OK, thanks. I already deleted all the emails off TWC mail website, so I will see how changing the server name goes.
After changing it, it seemed to work OK.
Thanks again, I'll let you know.
RicRat
Fri May 04, 2018 1:02 pm
Looks like changing the POP server worked.
I'm thinking Spectrum/TWC changed something and didn't notify.
Thanks again.
Fri May 04, 2018 1:03 pm
Great, fingers crossed then it's all smooth from now on.
