RBL can not delete from list
Problems/tips/tricks with MailWasher Enterprise, Windows and Exchange
darrenm
Fri Sep 11, 2009 10:00 am
Hello, not sure why but from the console when I am logged in as the admin account I can not delete entries from the RBL list - there are two I have incorrectly added. Is there a way to remove manually.
I have restarted the service but that did not help.
BTW I am running the latest proxy version 2.7.3
Re: RBL can not delete from list
Mon Sep 14, 2009 4:25 pm
Hi, not quite sure why this is as it's working ok (just tested) for us.
Anyway since you're not having any luck, you could remove them in the database directly.
These are stored in an SQL Lite database. Probably the easiest way to remore them from the database is by installing the Firefox SQL lite browser: https://addons.mozilla.org/en-US/firefox/addon/5817
Navigate to the installed program directory and locate mwes.db
Return to “Windows Specific”
