Pro. 6.2.1
budnick
Pro. 6.2.1
Mon Sep 22, 2008 3:06 pm
Hello.
When I open the program under the help section " this product is licensed to is blank". I do own the program and was wondering what the problem might be?
Thanks.
Budnick
Re: Pro. 6.2.1
Mon Sep 22, 2008 4:10 pm
If it is showing as unregistered try pasting in your registration key again.
If it is showing as registered I'd guess a glitch in the registry information, no idea on fixing it though.
Re: Pro. 6.2.1
Mon Sep 22, 2008 4:38 pm
It actually says "blank" ?
I wouldn't worry though, it just means that your name was not stored iwthin your registration code that was sent to you. It won't effect your registration with us.
budnick
Re: Pro. 6.2.1
Tue Sep 23, 2008 1:06 am
Hi stan_qaz and rusticdog
Thanks for the replys.
I does not say "blank" what I should have said is the space where my name should have been was blank.
It appears to function as a registered product.
On another note I never did receive a notification via email that Mailwasher Pro 6.2.1 had been released, yet I receive other emails from Nick Bolton.
Thanks.
Budnick
