Watch Netflix USA and windows update network error (and possible fix)
Pieter
Fri Sep 28, 2018 3:25 am
After installing the latest update kb4458469:
https://support.microsoft.com/nl-nl/hel ... -kb4458469
Watch Netflix USA gave a network error in the browser.
The fix was to give permission to the windows firewall again.
Hope this helps if you run into the same problem.
Greetings from the Netherlands!
huh?
Re: Watch Netflix USA and windows update network error (and possible fix)
Fri Sep 28, 2018 12:54 pm
Thanks Pieter, good to know. We also just pushed an update to put Netflix through a different server, that might have helped trigger the issue.
