Nothing in 'From' or 'subject' MW 7.11
Drdrill
Wed Oct 17, 2018 7:27 pm
Hi, the above problem has steadily got worse to the point where just about every email has nothing in the 'from' or 'subject' columns. This is happening with normal emails with short subjects and regular email addresses. I'm reluctant to just uninstall and reinstall in case there is a simple fix. I'm running windows 10. Any suggestions? Thanks
Re: Nothing in 'From' or 'subject' MW 7.11
Wed Oct 17, 2018 7:35 pm
Try first increasing the number of lines MailWasher retrieve for each email. Under Settings >> General >> Checking Mail >> set the Spam Throttle to around 500 lines >> Save >> restart MailWasher.
Hopefully that fixes it.
Drdrill
Thu Oct 18, 2018 6:27 am
So far that seems to have worked. Thanks!
