Fresh install on a laptop
mw62
Sun Nov 04, 2018 4:41 am
I have a Lifetime license and have been using Mailwasher on a desktop pc so far.
Within a week or two I will receive a (new) laptop. I am also new to using a laptop, I never owned one before.
Would like to have Mailwasher installed on the laptop as well.
Within the current license - is that okay?
(having MW installed on two devices, I mean).
Vainly tried to find an answer within the FAQ (maybe I am overlooking it) and tried to find the EULA
A search on License does not get me 'hits' that would provide me with an answer.
Re: Fresh install on a laptop
Sun Nov 04, 2018 2:04 pm
Yup all good, I know it's on this page https://www.firetrust.com/products/mail ... o/download we probably ought to add to some other places
"License to install on 3 computers. Includes 1 years use of all new versions, updates, real-time spam blocking and customer support for use with 3 computers."
If you want to copy across all data to the laptop, in MailWasher go File >> Export >> set the option to include learning, give it a file name and save location. Then once you have installed MW on the laptop, copy across the file and run it via double click. It will run and import all the existing accounts, settings, recycle bin, learning etc..
mw62
Sun Nov 04, 2018 11:13 pm
I just discovered .. it is also on the purchase page:
SnagIt-04112018 110808.png (55.04 KiB) Viewed 605 times
However, at the time when buying a lifetime license (at the introduction of Lifetime license, somewhere in 2011 I believe), there was no mention of number of pc's.
I do think a EULA-PDF should be made available (or at least add something to the FAQ).
thanks
