a few questions before buying
Red Bull
Sun Nov 25, 2018 7:08 am
hi
first of all sorry about my english 8)
I use 3 email accounts , all with imap protocoll
if i use mailwasher and i delete a mail will it also delete on my email provider ?
or mark a mail to spam what happens to this mail on my email provider ?
if i use mailwasher on my pc do i also need the spam folder on my emaol programm (em client ) ?
does anyone use mailwasher with emclient ?
thx
Mike
Re: a few questions before buying
Sun Nov 25, 2018 7:26 am
Hi Mike
When MailWasher deletes an email via IMAP, it flags the email for delete then issues the EXPUNGE command. That command tells the server to permanently delete all emails flagged for delete. MailWasher does this at the same time, so it gives the appearance of deleting from the mail server immediately. Some email clients for example only issue the EXPUNGE command when they are closed.
You can optionally set MailWasher to move emails you delete to another folder, instead of permanent deletion.
Red Bull wrote:if i use mailwasher on my pc do i also need the spam folder on my emaol programm (em client )
Yes, you can set MailWasher to check other subfolders.
Red Bull wrote:does anyone use mailwasher with emclient ?
Generally speaking the client won't matter too much as MailWasher works independently of client. You can set emClient to also not fetch emails as soon as they arrive, giving you the chance to view and delete all mails first in MailWasher and fetch the emails into the mail program as you need them.
Check out the 30 day trial, that'll give you a good understanding before you buy
Red Bull
Sun Nov 25, 2018 11:39 pm
thx
is it possible tio use a mini fanless pc for Mailwasher wich is always on
i can check Mailwasher per anydesk etc
thx
Mon Nov 26, 2018 3:23 am
That should be fine as long as it's Windows.
