Buying Hideaway
alan1951
Buying Hideaway
Thu Dec 06, 2018 11:59 pm
I have just downloaded Hideaway Beta & found that there were no options to add rules etc. I presumed that this is because it is the free trial version but found there is no way to buy a full version. Can you please tell me what the situation is.
Alan
Re: Buying Hideaway
Fri Dec 07, 2018 2:30 am
We're still working on the rules system.
Once the version is fully functional we'll return it to a pay program. So for now it's free with the simple redirect options.
alan1951
Re: Buying Hideaway
Fri Dec 07, 2018 5:00 am
I have found a problem. Trying to print to a network printer, the print program thought it was offline. I had to stop the redirect for the printer to work.
Alan
Re: Buying Hideaway
Fri Dec 07, 2018 5:50 am
Hideaway does ignore all local networks when you redirect your PC to another country. Do you know what model printer you're using and what IP address it's using?
AussieRodney
Re: Buying Hideaway
Wed Feb 06, 2019 1:21 pm
alan1951 wrote: Trying to print to a network printer, the print program thought it was offline. I had to stop the redirect for the printer to work.
Same issue. Printing to HP printers, 4630 and 7500 series. Since I only use the Redirect Torrent Applications option, it's easy enough to stop all torrents if necessary and Stop Redirect. Does my head in if I forget though! I usually leave it in main screen mode (rather than minimising), so that I don't forget to Start Redirect again.
AussieRodney
Re: Buying Hideaway
Wed Feb 06, 2019 1:37 pm
"Buying Hideaway"
It must be good to have people WANTING to PAY for your product!
Re: Buying Hideaway
Wed Feb 06, 2019 5:33 pm
Can you find out the IP/Network address of the printer? It should have it listed in the settings part of the printer screen
AussieRodney
Re: Buying Hideaway
Thu Feb 07, 2019 4:59 am
For me, 2 printers, both on the local network.
HP4630 at 192.168.0.15
HP7500 at 192.168.0.11
Re: Buying Hideaway
Thu Feb 07, 2019 9:18 am
Thanks. We'll need to do some tests on our side but shouldn't be hard to fix as it seems to be only affecting 192.168.0.* IP's
