"Evaluating Message"
bardos
Fri Dec 07, 2018 10:27 am
Is there some way to turn off 'evaluating message" which takes a while to do its job and meanwhile hangs up the whole program?
Re: "Evaluating Message"
Fri Dec 07, 2018 12:05 pm
If it's going slow, that will probably be the DNSBLs as they tend to be slowest. Try disabling those under Settings >> Spam Tools >> Origin of Spam ...see if it runs quicker then
bardos
Fri Dec 07, 2018 3:34 pm
Did that a few days ago, unchecked the two spam servers and there was no change... Don't think I had this in the past... just lately
Fri Dec 07, 2018 3:37 pm
OK, send me some logs, will see if it's noticeable where the slow down is.
Help >> Send Support Logs >> enter a brief note like 'eval running slow' >> in Ticket Number field enter chris >> Send Logs >> reply back here once sent.
bardos
Fri Dec 07, 2018 6:48 pm
What I did was a complete uninstall and then a reinstall... I suspect that all my firetrust folders were top-heavy from one update after another over the years, because some "junk" in those folders never came back on the new fresh install. copied over my accounts file and good to go... I'll see if the "evaluating" behaviour is left in the dust.... thx
bardos
Sat Dec 08, 2018 8:08 pm
New install solves any and every problem i had. Over the years I've been installing the upgrades one over the other. Starting fresh seems to work great
Danielf
Thu Feb 07, 2019 10:59 pm
bardos wrote:New install solves any and every problem i had. Over the years I've been installing the upgrades one over the other. Starting fresh seems to work great
I have done it but doesn't help.
I have still an issue with "evaluating" . It takes a while to do its job.
Thank you in advance for your help,
Daniel
Fri Feb 08, 2019 12:25 am
I don't recall seeing logs about this. Send them again in either case.
Danielf
Fri Feb 08, 2019 4:58 am
Hi Chris,
I sent you the logs.
Best,
Daniel
Danielf
Tue Feb 12, 2019 2:48 am
Hi Chris,
Have you found a solution to my problem?
Thank you,
Daniel
Fri Feb 15, 2019 9:30 am
Sorry Daniel, I've been on holiday while I move house/town
No, I didn't receive any logs. Can you instead go into Help >> User Files >> there will be a file called autosupport.eml >> right click on that >> Send To >> Mail Recipient >> email it to me at forum@firetrust.com
Chris
Danielf
Fri Feb 22, 2019 2:42 am
Chris
Hi Chris,
I am sorry but I don't have a file called "autosupport.eml " .
I also noticed that sometimes Mailwasher is closing unexpectedly. I have uninstalled the program and reinstall it but it doesn't change.
The issues concerning " evaluating messages" are related to my different Gmail accounts. For my other accounts, it goes fast. On my laptop,
I am checking the same accounts ( including the Gmail accounts) but there, it goes fast for all my accounts.
Best,
Daniel
Fri Feb 22, 2019 10:37 am
OK, can you go into Help >> User Files >> look for error.log, if present, email me that to forum@firetrust.com
Also there will be a Logs folder, go into that >> click on todays date folder >> email me the contents of that folder to address above.
Danielf
Tue Feb 26, 2019 9:58 pm
Hi Chris,
I sent you the files at forum@firetrust.com
Best,
Daniel
Tue Feb 26, 2019 11:06 pm
OK great, got them.
Your diamonds account is failing to logon, this will mean MW is likely timing out after 30 seconds, increasing the speed.
Your dafra3 and dafra1 also show a failed logon the 2nd time, working the first. As well as your Yahoo also failing both times...
All these accounts are using OAUTH, and I see from the logs you sent you are using Avast. My first thought is that Avast is causing some issues. I would recommend disabling any Avast email scanning and see how things go
Hopefully these links help
https://support.avast.com/en-nz/article ... d-settings
https://help.avast.com/en/av_free/17/se ... basic.html
If that's no good, try disabling OAUTH for the accounts under Settings >> Accounts >> Incoming >> Advanced >> disable Use OAUTH >> Save.
For your GMail accounts you will need to be sure Less Secure Apps is set to ON here https://myaccount.google.com/lesssecureapps?pli=1
For Yahoo it's here https://login.yahoo.com/account/securit ... ecure-apps
