Mailwasher Pro 6 Bouncing Not Working
AngelaIN
Sat Dec 15, 2018 7:59 am
Hello Experts-
I set up Mailwasher Pro 6 on my new computer. Tested bounce on several messages sent to myself from other emails. NOT WORKING.
I want to specifically bounce an email from a stalker and it's not working I changed the setting several times. Server Port 25. Server Port 465. Can someone walk me through
step by step the settings?
Thank you.
-A
Re: Mailwasher Pro 6 Bouncing Not Working
Sat Dec 15, 2018 1:25 pm
Some email providers do block bounces. Assuming this is your your email account you used for forum then you want
SMTP Server : smtp.gmail.com
Under Advanced :
Set Secure Connection type to SSL
This will use port 465
Set your SMTP server requires authentication, set also to use using same details as Incoming.
AngelaIN
Sat Dec 15, 2018 4:40 pm
Hello,
Thanks for the reply. No it's not gmail. It's my business domain.
Their website says the server is 465. I looked at my outlook and that is the server for outgoing mail, but
no TEST messages have been bounced back to me. :(
