When hitting the Mail Program, Outlook does not open.
enticer
Mon Dec 31, 2018 8:58 am
I just did a full Win 10 install due to many problems loading Win 10 over top of Win 7. And what a pain that was after 8 years of slush on the old H/D. Anyway I install MW from the start and installed my backup accounts and such. Had to do some re-figuring on the IMAP and SMTP along with Port number changes. Every thing is working but the opening of my email program (MS Office Pro 2010). I have many different changes to see if I can get it to work. I know I am missing something but just can't put my finger on it. (no pun intended) Any suggestions or help would be greatly appreciated
enticer
Re: When hitting the Mail Program, Outlook does not open.
Mon Dec 31, 2018 11:13 am
I also found that the Email Wash Settings does not read "Microsoft Outlook" and it says Hotmail, That I do not have. I tried the other 2 ways but do not see the install mail program.
Mon Dec 31, 2018 4:14 pm
I've heard of this happening when running an Outlook that has come pre-installed on the machine.
Try running a Repair on the Outlook install
https://www.companionlink.com/support/k ... 2013,_2016
or
https://support.office.com/en-us/articl ... b40c5bb88b
If you've got the Office key handy, you can also install Microsoft direct version instead https://www.microsoft.com/en-us/softwar ... oad/office of the preconfigured the PC maker would have put on
enticer
Mon Dec 31, 2018 5:01 pm
The key I do have and had for awhile did not work, I just bought another MSOP program in a box and I will try that key. And if that doe snot work I will move up to 2013 or 2016
Thank you
enticer
Wed Jan 02, 2019 2:50 am
Is there a way to go deep to change the email program for MW to open. All that mine show is Hotmail, which I do not use. And the something that says "other program". Which does nothing. I did get a new KEY for the MS Outlook 2010 and now it works just fine. I also uninstalled MW and reinstall but that did nothing and di not pick up on the activated Outlook.
Thu Jan 03, 2019 2:33 am
If you select "Use Other Application" and click Browse, you should be able to manually navigate to the location of the Outlook EXE.
It should be something like C:\Program Files\Microsoft Office\Office14\outlook.exe
Also if you had a shortcut to Outlook on your desktop for example, you should be able to select that also in MailWasher via the Browse.
enticer
Thu Jan 03, 2019 3:43 am
Neither works:
The 1st one: C:\Program Files\Microsoft Office\Office14\outlook.exe was not there, did find it in the Program Data file but did not work either. And I made a shortcut to the Desktop and that did not work. I will keep trying to play around with it.
Here is what I found and tried: C:\Program Files\Microsoft Office\Office14\outlook.exe Like you said but I get an error but the pic of Outlook is on the top line of the MW program
Thu Jan 03, 2019 3:56 am
Check for C:\Program Files (x86)\Microsoft Office\OfficeXX folders as well.
Assuming it's a regular Office install, and not a Win10 App, it should be present there somewhere
enticer
Thu Jan 03, 2019 4:07 am
This what did it :) .......... had to add the OUTLOOK.EXE extension to it. But it works. Thank you
C:\Program Files (x86)\Microsoft Office\Office14\OUTLOOK.EXE
