Dear MailWasher Community,
I have been using MailWasher Pro 6.5.4 for many years without a problem. Since yesterday I get an error if I try to check my Bigpond account via pop.telstra.com. I use SSL encryption on port 995 as specified here. It works fine with Thunderbird 60.5.0 but when I try to check my account for SPAM in MailWasher I get the error message: "Error connecting with SSL". I have tried to uncheck the UIDL command support or leave it in place and check Use RETR. But both settings produced the same error. I have attached a screenshot of the Thunderbird settings & another one with MailWasher settings but obfuscated the user account name.
I am looking forward to your suggestions.
Salut,
Mathias
Error connecting with SSL in MailWasher Pro 6.5.4
- MathiasBurbach
- MailWasher 6.5.4 settings
- Mailwasher_6_5_4.png (20.16 KiB) Viewed 7615 times
- Thunderbird settings
- Thunderbird.png (16.33 KiB) Viewed 7615 times
- aslilley
Re: Error connecting with SSL in MailWasher Pro 6.5.4
As of today, my wife has experienced the very same problem with her Mailwasher 6.5.4 connecting to bigpond.net.au
- MathiasBurbach
I have enabled logging in MailWasher Pro 6.5.4 and attached the session log.txt file. It looks like MailWasher is running into a EIdOSSLConnectError Indy error.
I have the feeling Indy won't support newer versions of TLS/SSL (see also here).
Is the only way to upgrade to MailWasher 7.11.10?
Salut,
Mathias
Salut,
Mathias
- SocketLog2.txt
- Session Log file
- (206 Bytes) Downloaded 593 times
- MathiasBurbach
I have since upgraded to MailWasher Pro 7.11.10. All fine now.
The old MailWasher used OpenSSL DLLs from 2006. Scary!
Salut,
Mathias
Salut,
Mathias
