Important notice for MailWasher and GMail accounts
RogNor
Re: Important notice for MailWasher and GMail accounts
Fri Mar 04, 2022 3:07 am
Just got an email from Google today03/03/2022 see below, what will happen with this?
waiwhite
Fri Mar 04, 2022 1:33 pm
I would be most interested in what we have to do.
The post that kicked this forum thread talked about a setting for OAUTH, however the latest version of Mailwasher does not have any such setting.
Now it looks like they want you to "Sign in with Google", so that means there will need to be an update.
If the sole issue was it being secure, what if you are using SSL to sign in?
waiwhite
Fri Mar 04, 2022 2:45 pm
If Firetrust decides the cost will be too high and does nothing, then it will not be good, and it will not be long before this becomes a requirement for other e-mail services that come with domain hosting, and even ISPS
DaveOzric
Sat Mar 05, 2022 4:00 am
Does anyone have an alternative? I hate to lose this program but I have too many Google accounts.
RogNor
Sat Mar 05, 2022 4:20 am
I'm in the same situation, I have sent a copy of the email to their support so will see what they say.
RogNor
Sat Mar 05, 2022 6:50 am
There is a work round for this, Link https://www.firetrust.com/products/mail ... quirements
I've also attached the PDF I was sent.
gmail.pdf
(526.35 KiB) Downloaded 2479 times
DaveOzric
Wed Apr 13, 2022 1:00 am
So an application password will work vs OAuth? That's interesting.
mw62
Sat May 14, 2022 4:55 pm
Stumbled over this thread, as Mailwasher showed an error fetching mail for my IMAP Gmail account and I should enable "Less secure app access". Indeed it was turned off.
When turning it on and this option will not turned off as from May 30.
Now what?
Using Office 365 Subscription based, Outlook Exchange with Gmail IMAP-accounts within the same application.
Sun May 15, 2022 10:12 am
Check out that link to create an App Password to use in MailWasher, your main GMail password stays the same as it was.
Using the App Password bypasses the need for the Less Secure Apps option.
davidswb
Fri Jun 03, 2022 2:43 am
From Google:
Less secure apps & your Google Account
To help keep your account secure, from May 30, 2022, ​​Google no longer supports the use of third-party apps or devices which ask you to sign in to your Google Account using only your username and password.
Firetrust, I hope you can update your program, because now a very good program it has become useless.
davidswb
Fri Jun 03, 2022 2:55 am
Finally, you have to create what Google call an APP PASSWORD
this then works with Mail Washer
HenkSecure
Wed Jun 08, 2022 4:13 am
Digerati wrote:
Thu Apr 04, 2019 4:01 am
and to be approved you must have your application audited, costing anywhere between 15000-75000.
:shock:  :crazy :rant
Can you say "extortion"? :(
Too bad, is this the end of Mailwasher?
Screenshot - 7-6-2022 , 18_05_50.jpg (38.68 KiB) Viewed 118815 times
Badotz
Wed Jun 08, 2022 6:37 am
I have a lot of gmail accounts, and setting up an app password for each will be a royal pita...if this is the only solution for accessing my gmail accounts through MWP, then I'm afraid I will have to find some other product to do my bidding, and that, too, will be a royal pita...
AjTeX
Thu Jun 09, 2022 1:18 am
gmail.pdf
Hi Thanks for this info... it worked perfectly for me, however would be great if Mailwasher updates this issue to work without this go-around.
David Jenkins
Sat Jun 11, 2022 6:59 am
gmail.pdf
This did not work for me. "App passwords" is no longer available from Google. I.e., the "App Passwords" prompt/button does not appear on the final 2-step verification page.
What next?
