Important notice for MailWasher and GMail accounts
blueboy714
Re: Important notice for MailWasher and GMail accounts
Sun Jun 12, 2022 2:13 am
@AjTeX - I was following what Gmail said to do. If you follow the above link and use the 16 digit password from Gmail in both your incoming and outgoing MW settings then it will work. I was originally following what Gmail said to do (use 16 digit password password for outgoing and your original password for incoming). Make sure for your incoming you include "@gmail.com" in your username and do NOT use "@gmail.com" in your outgoing.
Screenshot 2022-06-11 090635.jpg (67.28 KiB) Viewed 111616 times
willibus
Sun Jun 12, 2022 4:12 am
Using information here, I was finally able to get Outlook to download my gmail and to see it in Mailwasher - BUT - when I go to wash mail in Mailwasher or just clear it from Mailwasher, it also deletes ALL of it from my Outlook. I have looked over settings in both places and do not understand how to stop this. As long as this continues, I am unable to use Mailwasher which is a big disappointment. Anyone who can offer some help on this? It sure would be appreciated.
Pete
Sun Jun 12, 2022 9:54 am
rusticdog wrote:
Tue May 14, 2019 6:07 pm
_Chris_ wrote:
Tue May 14, 2019 5:59 pm
Hi all, is there an issue with receiving gmail emails via MWPro please?
You need to be sure Less Secure Apps is set to ON here https://myaccount.google.com/lesssecureapps
Then it should be business as usual.
But I cannot do this because Google has disabled the option of the ON setting!
I hope Firetrust is going to come up with a fix because otherwise I shall sadly have to delete MailWasher Pro.
Please respond.
Sun Jun 12, 2022 12:18 pm
Please respond.
If you create an App Password to use in MailWasher, that will work
pab200uk
Mon Jun 13, 2022 1:14 am
AjTeX wrote:
Thu Jun 09, 2022 1:18 am
RogNor wrote:
Sat Mar 05, 2022 6:50 am
There is a work round for this, Link https://www.firetrust.com/products/mail ... quirements
I've also attached the PDF I was sent.
gmail.pdf
Hi Thanks for this info... it worked perfectly for me, however would be great if Mailwasher updates this issue to work without this go-around.
Just a quick comment;
I created an app password for each of my gmail accounts and this one password works for all 3rd party apps you want to use from any source when accessing that gmail account; both mailwasher and 3rd party mail programs both on windows; mac and android. You have to use it for both retrieving AND sending email.
Unless Google changes the rules again to try and force users to use googles own app's of course; which is probably the reason why they did it in the first place.
Pete
Mon Jun 13, 2022 2:36 am
Please respond.
[/quote]
[/quote]
Thanks for that info.
As a very 'non-technie' computer user, I eventually eventually managed to get MailWasher working again.
Cheers, Pete
anniefriday
Thu Jun 30, 2022 11:52 pm
For any that are still struggling with this, I have an outlook.com address as well as a gmail.com address and set up gmail to forward my mail to outlook.com and have had no issues at all. https://support.google.com/mail/answer/10957?hl=en
Elektra
Sun Oct 02, 2022 12:47 am
Thank you for this solution. I got fed-up with Google's ever-intrusive nonsense and have been locked out of my Gmail accounts for over a year. Your solution allowed me to delete the Gmail accounts from MW Pro and get all mails forwarded to standard POP accounts.
Chariott
Tue Mar 14, 2023 7:31 am
Accessing that link posts
Google will automatically turn this setting OFF if it’s not being used.
Followed by
This setting is no longer available. Learn more
I'm getting confused.
Tue Mar 14, 2023 8:29 am
Yes, MWPro has always worked with gmail, however yes, google have decided to block all non email clients from accessing mail, and that includes MWPro.... (all versions) the only way around this is to use 2 step authentication and use an app password in MW, Nick has added this to our FAQ's recently here:
There is a .pdf file of this process here if required:
https://1drv.ms/b/s!Ak8zLigJcntTgaUvZKg ... A?e=WHsvN8
Once you have enabled 2 step authentication and setup an app password, here's how to setup the account in MWPro:
Open MWPro and click, Settings>>Accounts>>Add Email Account, enter a name for the account and your Gmail email address, click Save.
On the Incoming tab enter your Gmail app password you created earlier and click Save again.
Sujit
Beta Tester
Sat May 06, 2023 8:01 pm
Have been using version 7.12.25 without any OAUTH issues. I use 5 Gmail accounts. All use Gmail 2 step authentications.
Installed ver 7.12.139. Was prompted for a username, which I typed in. For the password, tried using the 2 step verification and the App password as suggested above. Also tried using the normal password for that Gmail account.
Neither of these worked. I get an error message "This App is blocked"
Should the current Gmail settings work with 7.12.139?
Sat May 06, 2023 9:39 pm
Have got a number of Gmail accounts running on the latest 7.12.139 βeta — all working fine . . . but, with app passwords & 2-Step verification (no OAuth.)
Sujit
Beta Tester
Sat May 06, 2023 11:46 pm
Tried this with app password (16 digit password). Still no joy. Not sure where I am going wrong. Seems to work with ver 7.12.25 though. Do I need to generate new App passwords for all my Gmail accounts under MWPro beta 139?
Sun May 07, 2023 12:24 am
BTW, the 7.12.139 is a βeta — it's recommended to stick to the stable 7.12.125.
For me, the same (16-digit) app passwords which were generated prior to the 7.12.125 continue to work fine with the 7.12.139 βeta, as well — I'm using the POP3 protocol on all of my Gmail accounts, though . . . not IMAP.
For Gmail, the following settings float my boat — if it helps:—
Sujit
Beta Tester
Sun May 07, 2023 4:22 am
Thanks. Will try it
