Important notice for MailWasher and GMail accounts
Sujit
Beta Tester
Re: Important notice for MailWasher and GMail accounts
Sun May 07, 2023 4:34 am
@ Trustfire The only difference to minwe is the "Security Connection" which mine is set as OAUTH. Yours is SSL/TLS. If I change all mine to SSL/TLS, will that have any negetive effect please?
Sun May 07, 2023 4:56 am
You won't face any negative effect by changing your Security connection from OAUTH to SSL/TLS — for your own peace of mind, though . . . you can change one account at a time (from the testing standpoint.)
Sujit
Beta Tester
Sun May 07, 2023 5:29 am
Hmmm... interesting. I had to go into Google 2 step and regenerate all my Gmail app passwords individually and put them in MWPro. Will not accept the old ones in there. Still, a small hassle but seems to work of with 139 bnow. Thanks for the help.
Sun May 07, 2023 5:47 am
Glad to see your issue resolved, Sujit. :thumbsup
Sujit
Beta Tester
Mon May 08, 2023 6:28 am
No issues with 139 so far. Am using SSL/TLS instead of OAUTH (Gmail accounts)
