Is the server broke?
sabarnett
Sat Apr 13, 2019 9:22 am
I keep refreshing the mobile app, but the list of emails does not change. If I then open the mail app, a flood of email arrives. Going back to the mobile app, the list of emails remains unchanged. It’s not changed for several hours now. Is there a pronblem with the servers?
Steve
Re: Is the server broke?
Sat Apr 13, 2019 12:07 pm
Hi, it looks like it might be. We're investigating.
Sat Apr 13, 2019 2:55 pm
Ok, it's working again now
sabarnett
Sat Apr 13, 2019 5:49 pm
Thank you.
sabarnett
Fri Apr 19, 2019 9:22 am
I think it’s broke again. I’m not getting updates on the iPad or the iPhone.
Fri Apr 19, 2019 10:40 am
Yes it is, we're fixing it right now
HJLenzi
Sat Apr 27, 2019 7:51 pm
Server seems still to be broken. I cannot download mails on my phone. It shows only always the same 3 mails, when it worked the last time correct (more than two weeks ago...).
I already de- and reinstalled the app. No success.
When do you think your server works again properly?
Sat Apr 27, 2019 8:02 pm
Oh no, it was working properly this week, but we'll take another look at it - seems to be a weekend thing :(
sabarnett
Sun Apr 28, 2019 1:06 am
FWIW, mine s working fine n the UK. Has been since the last fix.
Mon Apr 29, 2019 9:18 am
Yes, it's been working again now
MaxP00
Mon Oct 14, 2019 1:19 am
I keep refreshing the mobile app, but the list of emails does not change walmart survey . If I then open the mail app, a flood of email arrives. Going back to the mobile app, the list of emails remains unchanged. It’s not changed for several hours now. Is there a pronblem with the servers?
Steve filehippo
It's happening with me too. Been 3 months.
Mon Oct 14, 2019 8:42 am
Can you remove your account, and then re-add it in?
laugher
Sun Oct 20, 2019 12:33 pm
Using Mailwasher for Android for the first time. Here's what I am noticing.
  • Immediately after I open the app, the status at the bottom states "Synced a few seconds ago." It appears it states every time I open the app. I do not believe it because the message displays IMMEDIATELY. There is technically absolutely no time for the app to check my email and to sweep/analyse it.
  • If I pull down on the list to manually force a check, it also states the same thing "Synced a few seconds ago."
  • The list of emails in the Mailwasher app is from when I last opened it. For me, 2 days ago. Yet, it still states "Synced a few seconds ago."
  • It takes a few minutes for the list to actually refresh with a new list of current emails in the inbox.
The app isn't displaying actual status. i.e. logging into email server, checking email, download emails, analysing, etc. This will also help with determining if there is a problem at each of these stages but I can't determine when the app is doing what.
Mon Oct 21, 2019 6:40 am
Hi, it's a pretty basic hosted app, so when you pull down to get new emails, a request goes to the server to check for new email, then if you swipe down again and new emails are on the server then it will pull those emails in to view. We've been working on a new version which is not hosted, so all of this is much more immediate.
laugher
Mon Oct 21, 2019 11:34 am
Thanks Nick. I agree with the approach to localise the processing to the device with the current capabilities/offering.
