This app can't run on your PC
Silversinker
Tue Apr 16, 2019 3:52 am
Just downloaded the beta version & I get the following error message when trying to install - 'This app can't run on your PC'.
I have tried disabling my firewall, but it makes no difference :oops:
Re: This app can't run on your PC
Tue Apr 16, 2019 12:10 pm
Ok, that's odd. A quick Google of this gave me this website with lots of different options for solving it.
https://windowsreport.com/app-cant-run-windows-10/
I can't really give too much more insight of the problem because it seems such a generic message.
Silversinker
Tue Apr 16, 2019 7:24 pm
Cheers Nick,
Tried those, still same issue
Silversinker
Tue Apr 16, 2019 7:53 pm
All sorted. Took a punt & downloaded the file again & it installed with no issues. Must have been a corrupt download :D :D :D
Tue Apr 16, 2019 7:56 pm
Ok, can you try and right click on the installer and select 'Run as administrator' and see if that helps?
Ok, looks like we replied at the same time. Great you got it working and thanks for letting us know
