Font Size in Mailwasher Pro
pcbugfixer
Wed May 01, 2019 6:28 pm
G'day Folks (In the Island of the white cloud),
I can see a couple of fonts that can be changed to, 4 to be exact, however there is no option to increase the SIZE of the fonts.
With old age comes the realization that our eyes are not what they used to be so we need to be able to increase the font sizes to at least 14 please. With wider monitors (screens) we should be able to adjust the view for MailWasher Pro 7.12.x and up.
Can we look at this ASAP please.
Please don't go through the Win OS font changes, I would like MailWasher to have font change size ability.
Regards
Roger H.
pcbugfixer :devil
If you object to my “Candour”, read another post !
"BENE DICTUM, BENEDICTE !"
:twisted: The Devil made me do it !
Re: Font Size in Mailwasher Pro
Wed May 01, 2019 6:33 pm
Hi Roger
In the main MailWasher screen click the Display Options button near the top right >> in the Zoom section at the top click the drop down beside the A >> increase the font slider there.
pcbugfixer
Wed May 01, 2019 7:17 pm
G'day rusticdog,
Thanks for reply, looks straight forward except I am running Mailwasher Pro v7.12.1 in Windows XP Pro SP3 and the options you are suggesting ain't there.
I have a Display in Settings however no Zoom
In the main window of MW 7.12.1 there is no "Display Options button near the top right" I only have a Mail / Email / View / help / - menu style buttons however none contain a "Display Options button"
Any other suggestions please ?
Wed May 01, 2019 7:24 pm
Is it not showing just below the File | Email |View menu ?
pcbugfixer
Sat May 04, 2019 2:12 am
G'day rusticdog,
Again thanks for your help
Display Options are in the Settings menu on my MW, however there is no option to change the font size for / of MW.
Sat May 04, 2019 10:49 am
Sorry I wasn't clear, there are two Display Options, one you access from the Settings Menu, the other you should be able to access from the Display Options button in the main screen, as per screenshot above.
But from what you describe, you don't see the Display Options button in the main screen ?
Quick video showing it also https://grumpy.tinytake.com/tt/MzUwMjE5Nl8xMDUxMzczNA
jgt1942
Fri Feb 26, 2021 8:24 am
YEA this worked!!!!!
Thanks for the image!!!!
jgt1942
