Mailwasher Problems
- Hyperspace
Mailwasher Problems
Ever since I installed 7.12.6 it quit sending spam to Spamcop, so I uninstalled and reinstalled it and still didn't work. After I reinstalled it I notice it is only checking 1 mail account out of seven. So I uninstalled and reinstalled 2 more times but that didn't help at. I'm lost as to what could be wrong.
Re: Mailwasher Problems
Try sending some logs.
Go Help >> Send Support Logs >> enter a brief note like 'emails not checking, spamcop not working' >> in the Ticket Number field enter chris >> Send Logs >> reply back here once sent so I can check they arrived OK.
- Trip
Same issue with me after the update or on or about that time frame. Reporting to Spamcop does not work although it appears to work. I don't get a reply from Spamcop.net like I usually do. I check my spamcop account setting and they are fine. I check my settings in Mailwasher for Spamcop and they are set correctly from what I can see.
Do the same, sending some logs.Trip wrote: ↑Sat Jan 18, 2020 6:52 amSame issue with me after the update or on or about that time frame. Reporting to Spamcop does not work although it appears to work. I don't get a reply from Spamcop.net like I usually do. I check my spamcop account setting and they are fine. I check my settings in Mailwasher for Spamcop and they are set correctly from what I can see.
- Trip
- Trip
For what it's worth... I'm used to getting a notification when someone replies to my post. I don't see that option with this forum software. Is it available somewhere to be setup?
The board should email by default, you can check the notifications set here ucp.php?i=ucp_notifications&mode=notification_options
MailWasher is getting this error when trying to use the SMTP service.
Error: authentication failed: Authentication failed
Try going Settings >> Accounts >> Outgoing >> Advanced >> check the option to use the same settings as Incoming >> Save.
Great, thanks.
- Trip
Well this appears to have done the trick. I'm sending reports to SpamCop again. Thanks for the help. Still wondering how this setting got changed in the first place since I know I didn't do it.rusticdog wrote: ↑Mon Jan 20, 2020 11:42 amGreat, thanks.
